CWOP, Mesowest data, Wunderground not showing correctly after installing new Tempest replacement sensor
Hi guys,
So after getting this new sensor its causing my cwop data to act wierd including my mesowest data. I emailed them and this is what they said.
Thank you for contacting MesoWest. Unfortunately it appears the sensor change is causing your weather station to not transmit full weather data observation packets into the CWOP system. This can be seen here on this page which shows the CWOP-formatted weather observations your weather station is transmitting:
http://findu.com/cgi-bin/raw.cgi?call=GW0860
Typically the β€œβ€¦β€ entries in the formatted weather observations are numbers that are decoded as temperature, humidity, wind, and other measurements, but β€œβ€¦β€ indicates the weather station did not decode and send the data to CWOP correctly.
Our suggestion would be to reach out to your station manufacturer to see if they can help troubleshoot why the sensor replacement does not appear to be working for sending the data correctly to CWOP.
Even my wonderground data is not showing correctly.
Any reason why this is going on? I have not changed anything on my end with my meteobridge it shows it’s sending data out to these sites but something happened after I activated the new Tempest.
This is resolved I reset sensor binding on my meteobridge.
