Meteobridge/CWOP help
Just got my new Tempest unit up and working. I have connected it to my older Meteobridge unit. From the Meteobridge it reports to Wunderground and APRS weather (aprs.fi) without any problems. But for some reason I am unable to see any data reporting to CWOP. Here is the raw data I see on findu.
K0BL>APN000,TCPIP*,qAC,CWOP-4:@161635z4100.28N/09226.33W_007/002g005t039r000p000P000b10174h61L111eMB61
K0BL>APN000,TCPIP*,qAC,CWOP-5:@161640z4100.28N/09226.33W_349/002g005t040r000p000P000b10174h59L074eMB61
K0BL>APN000,TCPIP*,qAC,CWOP-5:@161645z4100.28N/09226.33W_234/002g005t041r000p000P000b10175h58L297eMB61
Would love some help with getting this to work. Also, I do not see any lightning data reporting on the Meteobridge live data page.
Thanks
Bill
Did you jump through all of the email hoops to get a station ID and stuff for CWOP? Just sending to aprs.fi is not enough. CWOP uses a separate station ID to pick up the data…
Yes. Should have said that in my first post. I previously had another brand of weather station and reported to CWOP. I registered using my ham radio callsign. The CWOP site shows my station as “inactive.” I believe it should have turned “active” again when i started receiving data??
Gladstone shows that they aren’t receiving your APRS data, if you want to trace it backwards from there:
https://weather.gladstonefamily.net/site/AT717
If I remember correctly, it takes a bit of time to start showing up if your station has been declared inactive. If you have given it a good bit of time, try sending email to cwop-support@noaa.gov for assistance.
Finally got it working. Had to email to get it active again.
Thanks
Does CWOP accept Tempest data? I had trouble finding that last year when I added my Davis.
