How to connect WF Air to Tempest Hub?
Hello,
I have had Tempest hub 1579 up an running for a year. I also have a WF Air from previous device that I would like to add as an indoor tempature and humidity sensor. I can’t seem to connect the WF Air to the Tempest Hub. I am using my iPhone to run the Tempest app. The LED on the hub turns blue when I run the app. I click on Settings, Stations, Select my station, click on Manage Devices, then click on the plus sign at the upper right corner. I place the batteries in the Air and close the cover. The green LED flashes 10 times, then glows steady for about 5 seconds. The LED on the hub flashes blue/cyan, but the Air is never “found”. Am I doing someting wrong, or is the WF Air not compatible with the Tempest Hub?
Thanks,
Constantine
Did you reset the Air ? Press long on the led till it flashes slow green.
Also some Air and hubs don’t like each other. Depends. Try already to reset the Air and try again.
What country are you in? Some parts of the world have products on different frequencies, and it is possible that the old Air/Hub combo are on a different frequency than the new Tempest’s Hub…
I was told to use two hubs, one for the air and one for the tempest, but I’m in the Netherlands and the frequencies are incompatable, which explains it. I don’t know where you are.
Thank you, all! Resetting the Air unit worked and it is now working. So, I guess that the frequencies are compatible.
