Min Max Trends on Temperature and Barometer
Hello,
I just set up my Tempest station today and also a Raspberry Pi hooked up to an external monitor.
Most of my Tempest station details are showing up on the Raspberry terminal but Temperature Max Min and Trend and also Barometer Low High and Trend is not showing up just dashes on it.. all the rest current Barometer measurement and Temperature - Wind etc. are showing fine.
Is there anything i need to activate or will it take a time perhaps overnight to appear the extremes and trend? the 24h data shows error but understand that’s because not been functioning for 24h yet
Thanks
Thanks for checking out the PiConsole. The temperature/barometer max/min should show and the trend should show after 3 hours. As you have just set your station up though, let’s give it 24 hours to see if the fields start to populate. It’s possible that with such a new station the API response is a little different to what the console is expecting. If it hasn’t fixed itself within 24 hours, I will take a closer look!
Thank you Peter much appreciate it :slight_smile: in case it helps my station id is 212665! I will see how it does within the next 24h.. been plugged now around 4h
In a PM, can you send me a copy of your wfpiconsole.ini file? I need that to test you setup on my end. Thanks!
@peter How can i send you a PM? donest seem i have the option. I have now the ini file.. or if you send me a PM i can reply to it
Apologies
I resolved modifying the ini file :slight_smile: Tempest is was wrong..!
Many Thanks for your help!!
Glad you got it sorted! Is this a duplicate post: Data missing on Raspberry Pi Monitor ?
It is indeed can be set as resolved..
One last question @peter when does rainfall from yesterday Month and year accumulate after midnight?
Today’s says now 0 wich is correct after midnight but yesterday month and year has a hyphen..
Also the 24h Temp difference has also a hyphen, hasn’t updated after midnight.. any idea?
Also Max Gust for today shows 3.4 mph when on the app Tempest says 2.9mph so far what could cause that?
Feel free to send me a direct Message I can get the.ini file again for you tomorrow if needed
For these rain fields to populate (and the 24 hour temperature difference) I’m pretty sure the console needs to be running for at least 24 hours.
The temperature difference is the difference in temperature now (08:22) compared to the same time 24 hours ago, so if your station was not setup by 08:22 yesterday, then it will still show as dashes.
Thank you Peter that’s really helpful :slight_smile:
On regards of the gust any idea on the discrepancy compared with my Tempest data? It always shows more.
Thanks again
