Power cut causes Hub to disconnect
Hi All WF’s,
Every time there is a mains power interruption here the hub goes RED and stops sending data.
The only remedy appears to pull the micro USB, wait, then replug - it then show GREEN as it reboots.
Fine if I’m around, but there have been interruptions when I’m not at home.
Any suggestions to guarantee an uninterrupted data stream gratefully received…
4 posts were merged into an existing topic: Hub offline after power outage
