Pressure all wrong
I just noticed that my pressure is way off, but height of the device and height of the station are set correctly. Could someone from @weatherflow have a look?
Indeed you’re living in outer space now …
except kidding, I see there was something fishy April 18th. Just for confirmation, did you change anything that day that might have triggered something in the calibration ??
I’ll ping support for you
Sunny can you please reset the Air ? Just open the battery lid wait like 10 seconds and close it. It should reconnect and come back, see if this helps the tech folks and your pressure reading.
Looks like a failing BMP280 (pressure sensor) to me. If a power cycle doesn’t restore sanity, open a ticket with WF support for a replacement…
If it would have frozen at 666 hPa I would have said it was possessed!
Indeed looks like it could be a failing sensor. Contact us for a replacement AIR unit if you’d like.
