My Sky unit stopped reporting as of 12.00pm yesterday… weird date/time…
I haven’t made any changes to my setup, and batteries shows 3.2 Volts as of yesterday. I tried moving the hub to a different location in my house… didn’t help at all.
Does anyone have a clue. Right now it got removed I guess from my Weatherapp in the phone…
Niklas
Have you tried resetting the device and adding it back to the Hub?
I did that too guess what ? All your history is gone ! maybe @WFmarketing can jump in here this is a not wanted scenario
His Sky is already disconnected. He can pair it again and then the old data can be joined. Until it’s paired again he is losing data.
As far as I can see his SKY is is connected again the history goes back 2 a 3 hours I think he got a new device ID number
edit @GaryFunk indeed he’s disconnected again when I looked at his station he was up again for about 2 a 3 hours atm theres no SKY
I don’t know what he’s doing. I think he’s pressing the wrong buttons.
LOL can be well lets see what happens
Yep, history is gone… Bye bye bam…
It’s not gone. It’s still in the database under the former device ID
You can ask weatherflow too merge the old data to your new devicenumber I think
Mine keps going down every hour or two
Readding it doesnt seem to help
Is there a way to reset it instead as see if that works?
Are you having any strange weather that might be causing that?
Not really. Fog. 6 C. Calm no wind.
Watch the RSSI values on the Sky and see if they drop below -80.
Thanks. I dont know where to find those or what they are…
Press the Gear at the upper left corner.
Press Stations
Press your station
Press Online at the lower right
Scroll down to see your Sky device then look for RSSI.
Im getting
Hub: RSSI -68
Air: RSSI -58
Sky: RSSI -52
@nickez28 . Strange. WeatherFlow Customer Support will take a look at your account when they are back in the office tomorrow 14 Nov.
That looks good. Just don’t delete the Sky if it fails.
