Hmmm how would I verify that Eric?? So what I did was AT&T router was turned off and I used IP pass through mode cause they router is garbage so I am using my nighthawk which I bought. The meteobridge is connected to the phantom via a cat 5 cable. I think it’s half right since I am getting the green check last and I can log into it. But yea why no sensor raw data that’s we’re my problem is I just know it. I also setup and IP reservation for the meteobridge I thought I would mention this to.
Omg fixed!! Check it now it’s rapid updating in WU and cwop. I had weather flow station added as main station and then as first station so double. I removed and now have only 1 as primary. I now have raw sensor data
Please look when you can links above
there you go, you found the solution. Running nicely seems. Enjoy
