dsfg
January 18, 2020, 6:59am
24
As Corrine from WeaterFlow pointed out here in an other related topic:
Hi @cotedan ,
The air temperature and humidity card displays the Feels Like value when Feels Like differs from air temperature. If those values are the same the Dew Point is displayed on the card. So it is possible that you will see the value on your card switch between Feels Like and Dew Point at different times of the day.
Information on how the Feels Like temperature is calculated can be found here .
It is possible to see “feeels like” what’s nearly the same as wind chill and another time “dew point”.
Crossly said, when wind is strong you might see “feels like” and in calm situations “dew point”.
David said a few ore more, earlier in this topic
Sorry about that, Gary. This is something we need to address, but it’s not technically a bug… Despite what we may have written before, it turns out the “card” view will NOT show the wind chill value, even going by it’s other label, “feels like” - not even when it’s cold & windy! And that’s the expected behavior on all three apps (Android, iOS & Web). Here’s the rule as currently implemented in each app:
If the calculated heat index temperature is greater than the raw temperature, then display …
