I have noticed that the wind today has almost been from the SW10-20 kmh. However, the description has been saying North to NW, I have the Tempest almost oriented due north (with a slight offset. Thoughts as to why the info is conflicting? I also included a capture of a map with a few other weather stations
looks likes a problem, because when it is pointing almost North, it is stuck at a very specific orientation. Not exactly North, but still a problem. Did you perhaps rotate the device slightly in the app? (not that this would solve the problem, but might explain why it isn’t exactly North).
