Wind Chill feature
@peter, thank you once again.
I have been using the “rest/observations/station” request in almost all of my queries
I reran: https://swd.weatherflow.com/swd/rest/stations?token=####
and it listed three devices of device_type HB (home base?), SK (sky?) and AR (air?)
if I run: https://swd.weatherflow.com/swd/rest/observations/device/44665?token=#####
where 44665 is the device_id of the SK device then I see the obs_sky array, which includes wind data (yay!!):
    "status":
        "status_code":0,
        "status_message":"SUCCESS"
    "device_id":44665,
    "type":"obs_sky",
    "source":"cache",
    "summary":
        "precip_total_1h":0.0
    "obs":
            1607688638, index 0: Epoch (seconds UTC)
            0,          index 1: Illuminance (lux)
            0,          index 2: UV (index)
            0,          index 3: Rain Accumulation (mm)
            0,          index 4: Wind Lull (m/s)
            0,          index 5: Wind Avg (m/s)
            0,          index 6: Wind Gust (m/s)
            0,          index 7: Wind Direction (degrees)
            2.15,       index 8: Battery (volts)
            1,          index 9: Report Interval (minutes)
            0,          index 10: Solar Radiation (W/m^2)
            0,          index 11: Local Day Rain Accumulation (mm)
            0,          index 12: Precipitation Type (0 = none, 1 = rain, 2 = hail)
            3,          index 13: Wind Sample Interval (seconds)
            null,       index 14: Rain Accumulation Final (Rain Check) (mm)
            null,       index 15: Local Day Rain Accumulation Final (Rain Check) (mm)
            0           index 16: Precipitation Analysis Type (0 = none, 1 = Rain Check with user display on, 2 = Rain Check with user display off)
I believe that HB means hub.
Ah-ha! Hub. Of course. Thank you so much!!! :slight_smile:
