Air Station Continually Disconnects (Solved)
nothing complicated
go to the webpage of your station, down right there is a green dot with ‘online’ (hope so), just click on the dot. It will flip over and there you will have all the technical details of your modules. Look for your air and see RSSI … if it is -80 or worse then it is limit reception (yep values are negative so closer to zero is better)
