How do I add Sky?
Apparently I’ve reached the max responses for my first post so I was cut off from answering you but yes, that is when I get “Error syncing data”
You have done everything correctly. Reset the Sky then open the battery door. Keep it open one minute then close the door and try to add it.
Uninstall the WeatherFlow application then install it fresh from Google.
pushed your status, you should be able to post normally now.
That finally did it!
Was up at 4 this morning to see if I had missed anything from you overnight
Thank you SO much!!
I’m happy I could help. Enjoy your station.
