When I installed my original Air/Sky several years ago, I set up a Meteobridge unit to aggregate data from my Air/Sky unit for use with Meteotemplate. Recently I purchased a Tempest unit to replace the Air/Sky, but discovered the Tempest data being forwarded to Meteotemplate is either missing or incorrect. I checked the Meteobridge log and discovered the previous Air/Sky station is still configured as the primary station, with the new Tempest as secondary (see logfile output below). This results in incorrect sensor data mapping, which means incorrect or null data is being forwarded to Meteotemplate. I see no way to remove or reorder the Weatherflow units in the Meteobridge configuration. I suppose I could reflash the Meteobridge and start from scratch, but am hoping someone else using the Meteobridge is aware of a more elegant solution.
Brian Leverson
logger (09.02.2021 10:03:50): data logger (version 5.1e, build 3758) started.
logger (09.02.2021 10:03:51): connect station 0 (Weatherflow via SW Driver).
logger (09.02.2021 10:03:52): station 0 (Weatherflow): TEMPEST TS-00013455 already registered (wind0/rain0/uv0/sol0).
logger (09.02.2021 10:03:52): station 0 (Weatherflow): AIR AR-00000213 already registered (thb0/th0/lgt0).
logger (09.02.2021 10:03:52): station 0 (Weatherflow): TEMPEST TS-00006308 already registered (wind1/rain1/uv1/sol1).
logger (09.02.2021 10:03:52): station 0 (Weatherflow): TEMPEST TS-00006308 already registered (thb1/th1/lgt1).
logger (09.02.2021 10:03:52): sensors are now providing data.
logger (09.02.2021 10:03:52): services started.
