hello everyone, just got google fiber Wi-Fi installed changed from att. my hub worked fine with the att but as soon as i got the fiber installed it didn’t. I’ve reset the hub, deleted the systems, added a separate 2.4ghz channel on the Wi-Fi and it still will not recognize the new Wi-Fi or pick it up,
sos. i spent a lot of money on this system.
Try setting your hub to your phone’s hotspot for a little bit, then try changing it back to your new Wi-Fi. I’ve had that fix Wi-Fi issues in the past.
