Solar Sensor NOT Working
I installed my unit on 9/22/18 and everything was working great for almost a week, then the data for the solar sensor became spotty, then stopped just a couple days later altogether. I was hoping it was a firmware issue, but when revision 98 came out, there is still nothing. As can be seen with my profile picture, there is nothing to block it being on the roof.
I am wondering if @anon84912554 or @WFmarketing could maybe shed some light on the issue. The only other thing I can think is that the sensor itself came out with a defect. If that is determined to be the case, what can be done about it? I’m station No. 5372.
Thanks!
Send an email to support@weatherflow.com stating the issue and your station ID.
I just looked at your data and you do seem to have a defective unit. If so, WeatherFlow will send you a new Sky.
